Mark Gomez
is where the surf is
- Fullerton, CA
So Here are finally the pic's and spec's about my Ski let me know what you think. It's been the focus of all my cash and brain power but I love it and love working on it so heres the pic's... click to enlarge
BODY
First of all i bought this thing Bone stock other than the after market "I know Victoria's secret" stickers that i took off and had only 30 gal of gas pumped through it. the thing was Cherry you could eat out of the inside of the hull.
-Took off all the old Vinyls to clean it up.
-Picked up a bunch of Black Diamond cut Hydro Turf and put that outside my ski rails, the hood to stand on it and grip while maneuver around it, for my footholds, and on my hood for scratch protection of the hood latch and my hood strap clips.
-Replaced the gas cap with the PJS Chrome Emblem to fill the hole.
-Nose reenforcement brackets
-"Beef it" handle pole reinforcement
-O degree Freestyle bars W/ ODI beefy grips
- SXR Lanyard Start and stop Switch
- Bilge On and off thumb switch right bellow the O/F switches
- Jet works Quick Steer plate
- Primer
-Hot Producs Water Strainer
- Home made Handle Pole Extension Limiting Rope
- Blowsion Hood straps for SXR that i made Work:biggthumpup:
Engine/Electrical
-Ocean Pro Head Front:225 back:230 Compression
-Original Cylinder and Pistons Stage III Ported & Decked Cylinder by Former PJS Technician Eric Stevens
-PJS Exhaust Manifold
-PJS Head and Chrome Pipe
-Jet Works water flow control Valve
- Boyesen Bottom end Power reeds
-WestCoast Mikuni 44 Intake Manifold
:hail:- Jet Works 44mm Mikuni Black Jack Carburetor:woot:
- Fly Flame arrestor (the little wetsuits work good mines drying i cleaned it)
-MMF Racing Waterbox
-5 Gal Big Tank
-Removed Rev. Limiter
- Dual 500 GPH Bilge pumps (Concealed and all wiring tucked away:biggthumpup
-Whats Missing that i know of?
- A flippin RAD Charging Light weight Flywheel! (too expensive to buy new:banghead: :banghead
PUMP
-15 Skat-trak prop
-Oceanpro Extended Pump Vein Bored nozzle
-PJS Top Loader Intake
And for my most amateur but proudest custom work I have done so far.
:arms: The Footholds
urr:
I Pulled an all nighter the night before last 4th of July's Week long Lake Trip to Clear Lake CA. So they were definetly not made for looks being all the excess ugly silicone ive yet to clean up. But I just built as i went with one idea building onto another.
The whole concept was based upon the use of the Blowsion/Hydro Turf Lifter Wedges. One alone wouldn't keep my feet in, so i wanted to use two yet the pull of my feet would easily rip them out with the leverage of being so tall with no real strong base support. Thus my idea started with the concept of wraping the stacked blocks in hydro turf so both ends of the wrap would be glued down providing the strong and most of all, wide base to distribute the abuse of pulling up on the blocks.
What I Used:
-Hydro Turf Lifter Wedges
-Contact Cement (lots of brushes)
-Silicone II(Wish i knew there was Black... would have come out better)
-Stainless steel Wood screws and Washers
-BIG sheet of Black Diamond Cut Hydro Turf (also used it for my hood and the trim of my ski)
:hail:- 2 large Monster Energy Drinks(Wouldn't have made it without em)
I took these Photos with my camera phone a year ago when i made them. but its all i have of the process...
-The first step was obviously measuring where they were going to be put and what angle for my feet.
- I then glued the two Blocks together and Cut the grove for what would be for the front arch of my foot.
- Glued them to the ski at the measured spots and angles and Threw in some Wood screws and big washers for inner structural support.
(This was the wrapping Concept i was talking about)
-I had to use the diamond cut i wish i had regular for this but i had to sand, cut, and measure little strips of the Diamond cut as you can see to make the top of the foothold nice rounded and solid so I could pull my Blanket/Cover of turf over it. (This took FOREVER to get and make it look right:banghead
-Measured 50 Times then Cut, put it on dry, cut again, measured, cut, Placed it on dry again, and finally Glued it on.
-Added Screws at the bottom to prevent the Plastic Stock 550sx side tray from wanting to pull itself off.
-Measured and Cut Turf to Match and Fill in the exposed sides
-Glued them in
-Finished with the silicone around the edges
-Luckily even finishing 3 hours before I left it wouldn't be less than 24 hours before i hit the water(drying time
urr:fect)
These are what they look like today :biggthumpup:
I Rode one time with a temporary version of these with only one on my right foot when i went to ocean side and it made control of my ski in the air ALOT better. So I cut the bottom straps i don't use on my back pack that bugged me and before i threw em away i realized that they were beefy enough to be my Foot straps. Thus, with a few more Stainless steel wood screws and washers, some BLACK silicone(i learned my lesson), and some careful measuring...
Bling- Toe-in straps :Banane35:
And Yes, I will get around to Cleaning up the old clear ugly silicone around the edges and replacing with with black.
Thats my SKi and Footholds Let me know what you think!
Thanks
-Mark
BODY
- Primer
Engine/Electrical
-5 Gal Big Tank
PUMP
-15 Skat-trak prop
What I Used:
-Glued them in
Thanks
-Mark
