What pump for xscream dvx
My vote hands down is the Torrent 155. One of the best pumps on the market because of the support that comes with it. Brian will listen to what your set up is and get you a prop that is perfectly sized for your application. Also the quality of these pumps is amazing. Absolutely pieces of machining art. The performance is there too. Look at Gomez, Anyzeski, and Krefski. All sending it huge on Torrents.
My vote hands down is the Torrent 155. One of the best pumps on the market because of the support that comes with it. Brian will listen to what your set up is and get you a prop that is perfectly sized for your application. Also the quality of these pumps is amazing. Absolutely pieces of machining art. The performance is there too. Look at Gomez, Anyzeski, and Krefski. All sending it huge on Torrents.[/QUO
definitely torrent thanks bro
Christian_83
Xscream
Denmark
No questions asked. TJ products 158mm. Ive seen the pumps IRL. These are work of art.
They have been testing 158mm pump vs 155mm in 900-1200 with great results.
Altso the TJ pump uses a new catch ring system. Im pretty sure the TJ pump is about the lightest aluminium/stainless pump on the markt
I have a few TJ Products in my Helium and I am very happy with the quality and performance.
I switched from 49 Full Specs to billet TJ 52 carbs and noticed a huge gain in performance. We had to repitch my prop, because it was spinning with my new carbs. 2 month later I bought a TJ 158 pump. I could not believe how light it was, compared to my xscream pump. The ring has a different design and holds the pump much tighter. I would run the pump on any other hull on the market with a standard pump shoe installed without any doubt. Installation was easy.
A few weeks ago I got my TJ pump cone. You can change the size of the cone with shims. Very easy to do at the lake. Takes about 2 minutes.
Prices are very attractive and Tim is easy to reach via Facebook messenger.
By the way, Tim is an incredible pro rider and engineer. On the water he is not as good as his wife Jessi, but pretty close ;-) Check them out on FB or Insta. Tim Verheij & Jessi Verheij
Christian_83
Xscream
Denmark
TJ is Tim and Jessi Verheij.
Also like Stefan said, he has made a adjusable pump cone system that is super neat and easy to change pump cone lenght it like 30 seconds.
I only think there is a handfull of guys in the world with the technical and mechanical skills who also can ride on a pro level.
71305228_2373828122933803_53294136052154368_n.jpg71076475_529933631096657_5009323616928530432_n.jpg67980388_488096278641170_8110323200442761216_n.jpg
