- Guernsey Channel Islands
Hi guys i have been reading posts on squish gaps and see you all seem to use soft core solder, i do it a different way which IMO is more accurate.
you will need a reasonable quality dial gauge and extension and spark plug adaptor (i find a digital is easiest to use ) it is also easier if you have a spare piston of the same type dome.
1/ install plug adaptor into head dome and fit dial gauge
2/ with your dummy piston place centraly onto the squish part of the dome and zero the dial gauge (i always check the dome of my new pistons with that of my dummy)
3/place dome/gauge onto cylinder (i remove orings) and turn motor over and at TDC the smallest number you get is your squish
4/ on motors with 1 piece heads i assemble the topend and torque the head to the cylinder , install the dial gauge and slide my dummy piston into the cylinder till it bottoms out on the head and zero the gauge , then install cylinder and torque down and again turn motor over to TDC and the smallest # is your squish
[/URL][/IMG]
[/URL][/IMG]
i hope the pictures explain a little , a good dial gauge is worth its weight in gold if you do a little motor work also essential for zeroing degree wheels to work out the dwell at TDC
regards Neil
regards Neil
