@THRUST linkage all day. No backlash and allows the tiniest bit of angle movement up down side to side
Will that fit on the carb shaft..?
throttle shafts are a hair smaller than 8mm, so no it wont fit. you could probably drill it out to fit. not sure what its made out of or if its springy enough to work.Will that fit on the carb shaft..?
View attachment 332573 I've been using these high priced couplers for 25 years. Still need to drill them out from 5/16" to 8mm (easily done hand held) and also change the 2 crappy socket head cap crews for ss ones. Expensive but very reliable.
ImpressiveView attachment 332574 View attachment 332575 View attachment 332576 View attachment 332577 View attachment 332578 View attachment 332571 View attachment 332572 View attachment 332573 I've been using these high priced couplers for 25 years. Still need to drill them out from 5/16" to 8mm (easily done hand held) and also change the 2 crappy socket head cap crews for ss ones. Expensive but very reliable.View attachment 332571 View attachment 332572
So, I might only switch the jet size 120 main/115 pilot with the same pop offOverall jetting is the same either way. But the fuel curve changes slightly when you go back and forth between reverse and standard jetting. Very small change in your case
