Hey Guys,
I just want to show you what you can do with a common 3D-Printer if you are bored and a cold winter is sitting in front of your door.
I´m using a Ultimaker 2 Extended with 2,85mm PLA Filament (many different colors available).
First I started with something simple.
Short Freestyle Pump Cone.
After it worked great for me, decided to build a Frame to get a clear view inside my E-Box.
Sealed/glued the frame with rtv silicone to the back plate of the E-Box. Frame is screwed from the Backside. The plexiglass is screwed from the front side and sealed with a o-ring, sitting in the notch of the frame.
Printed some spare parts for my Flyboard stuff
Next big project was to build my own design intake manifold for dual 49 Full Spectrums.
This design is used with the oem reed cages. I used Würth Time Serts for the threads in the manifold for not stressing the plastic threads when I adjust my carb jetting and remove the carbs a few times. It runs awesome!
A throttle drum just for the case I need one…. Anytime
