- Phoenix
Hey guys, I'm in the middle of starting a massive undertaking on the FX-1. Freestyle build to the max!!
I will be doing the following:
Hull mods
-Custom adjustable footwells
-widened tray
-Rocker Kit Carter B
-Tubbies Tom21
-Exhaust rear side exit
-Scupper valve side exit (to match rear exhaust exit)
-Dual drain plugs out the rear
-Internal fill (closing external fill)
-Hood modified for freestyle
-Hood hand holds
-144 Aluminum pump shoe
-Carbon reinforced engine bay
-Carbon ride plate
Motor
-62T Cases
-61x cylinder head
-ported and polish
-785cc sleeved
-Wiseco pistons
-Hotrods Crankshaft
-ADA Girdled Head 35cc domes
-46mm mikuni carbs dual
-R&D intake
-carbon V-force reeds
-Factory B-Pipe
Pump
-144 Solas 12 vein mag pump
-custom trim W/protec nozzle
-freestyle pump cone
-Impros prop
-Solas billet prop seal
Other odds and ends:
-Custom fuel cell
-Total loss electronics
-Thrust innovations quick steer
-Carbon bars
-Trim and throttle levers billet
-custom waterbox or aftermarket one
-primer
-bilge pump
-new cables through out
-new fuel lines/cooling
-dual cooling
Think thats it, any thoughts?
Hull mods
-widened tray
-Tubbies Tom21
-Hood hand holds
-Carbon ride plate
Motor
-62T Cases
-61x cylinder head
-ported and polish
-785cc sleeved
-Wiseco pistons
-Hotrods Crankshaft
-R&D intake
-Factory B-Pipe
Pump
-Impros prop
-Custom fuel cell
-Carbon bars
-primer
-bilge pump
-dual cooling
