I purchased a used rokr last week that will be next week sometime so I figured I would start a build thread. So as of today I tore down my donor ski "orangie". Turns out it was a little more beat then I thought. The xscream 61x has a melted piston, blown front crank seal, frozen up B pipes bolts, wiped out midshaft, and the fiberglass was beat on it. With that being said not a lot will get transferred over to the RokR.
The plan for the RokR is -
ported 781BB (62t/61x)
Dual mikuni 38's
ADA head 35cc
Ported B-pipe with blaster chamber
RRP cast pole
Stock 144 pump
Thrust trim
More of a budget build but should still be a solid ski. More pics to follow once the ski is delivered Thursday.
Sent from my HTC One_M8 using Tapatalk
Dual mikuni 38's
ADA head 35cc
RRP cast pole
Stock 144 pump
Thrust trim
