What are some peoples thoughts on running a pfp as a wet pipe I might be getting a pfp used the chamber is cracked and would have to be fixed to made a wet pipe. What is everyone's opinion on that
Most say its a better way to go. It will also reduce the weight of the pipe to keep it from cracking again, because when the pipe is ran in dry form and the jacket is full of water it weighs like 20lbs or something
Pfp will hit harder on the bottom, but quit pulling much sooner. You're better off getting the new tnt chamber or rrp pipe if you are going to run it wet.
Im running my pfp wet and it pulls really hard lower but i didnt notice it stop pulling up high like some claim it will. However i still run the water around the chamber to keep the heat down inside my hull. I cant really tell a difference with the extra water weight it flips the same to me.
What prop should I run I'm running a 701 full 62t with ada head 35cc domes msd enhancer and a nynja pipe now with dual 44s
And I have a hooker 9/15 prop in it on a aquabot v2
Pretty sure the chambers have a lifetime warranty. I would up your comp and ride it dry. Hookers leave a good bit on the table for a dry pipe setup, but with a little tweaking they can work very well.
