SkiDiggity
formerly kawirider142
a pole in the honeycomb would look soo sick!
Can you show some pics of how you are bonding the two halves and finishing them.
The bit of composite work I've done is leaving me struggling to understand how you got the OD surface of a part to be that good. Is there a step I'm missing? Something special about these sleeves you speak of?
perrrrty! nice work dude!
What are the carbon midshaft guards goin for $$? that honeycomb carbon one is sweet
Damn, thanks for the description! I've never worked with heat shrink but I guess it is similar to doing wet layup vac bag, just the sleeve is applying pressure instead. Are the sleeves and heat shrink tubes all made to order (ie you send a company dimensions of your part) or are they available in a lot of generic diameters/lengths?I don't really have pics other than those posted on the last few pages. They should show most of the process. Basically the OD was set by the plug, which the molds were pulled off of as a mating pair. So the parts out of the mold, once trimmed, match up almost perfectly (minor trimming variation). Once trimmed, they are mated and then masking tape wrapped around the top, bottom, and center. Body filler is than applied to the seam to "tack" them together and fill the seam. Tape comes off and more sanding and body filler is added until the seam is perfectly smooth.
Once smooth, a braided sleeve is slid over the pole and then pulled tight. Resin is brushed on and then a heat shrink sleeve that was coated prior with a mold release is slid over the pole. Heat is applied and all of the air bubbles and excess resin is worked out with a spreader. This takes a bit of practice to get right.
After the sleeve has cured, the heat shrink is cut off. The finish at this point depends a lot on how smooth you managed to get the heat shrink. Loose ends are sanded off, holes for the steering are drilled, and a forstner bit is used to set the 5/8" SS washers into the pole. Bolt center is then drilled out and the washers are bonded to the pole with epoxy. The tongue is filled and sanded smooth, as is the bottom of the pole. The whole pole is block sanded down with 150 grit until the top layer of carbon is hit. The tongue and bottom are taped off and then a high build primer is sprayed and a black base coat goes over that.
Sunshield is sprayed over the whole pole. Sunshield is a polyester based clear coat that builds very well and dries smooth. Once this cures fully, the pole is block sanded a second time with 150 until smooth (or we hit the carbon layer again, in which case another round of clear has to go on to build the low spots and we repeat sanding). A final round of sunshield clear is shot and cured. Once cured, pole is wet sanded at 1000 to remove orange peel, then 2000 and 3000 before compounding with a DA and M105. Polished with DA and M205.
