- Charlotte NC
i know there are quite a few of these out and floating around now, im wondering if any of yall have played with chamber temp? The main question i have is how hot is too hot? Or a stay below x temp. Thanks
ok, i guess its time to change the title again. What i want to know is what time are you running your rrp pipe at....... there
Josh you fail at this whole x-h2o thing. Let Matt and I handle it so you can get back to building our skis
Running a 120 jet in 57 to 60 degree water and pipe temp is right below 100 but the hit is good riding flat water.
Switched to an 80 jet and temps still below 104, but exhaust sounds more noisy/raspy/barky now and the hit seems the same or slightly less with louder exhaust noise.
Restricked the water box with a 2.5 carb seat and exhaust got louder, more raspy/bark but no more power.
So far it seemed the pipe system likes backpressure & water
Just switched to a bigger pv engine so have to re-check it but I think I'll tune the pipe based on hit not temp.
weird???I wouldn't tune the RRP pipe by temp, the RRP install sheet called for a #105 jet btw.View attachment 274190
