N3vrSat1sfied
Military Member
- Fort Worth, TX
Well I have started building a 2nd Q8, this one for the wife, So thought I'd share the progress. Practically stole this hull, it is a 2013 Q8 sky that has never seen water as you can see the breather holes are not drilled etc. It was only 3 invoices apart from mine and ordered 4 days before I ordered mine.
Specs:
HULL:
- 2013 EME Q8 Sky
- Jaz 2 gallon fuel cell
- Xmetal scupper
- Xmetal KDX footholds
- Ride plate cut flush
Engine:
- 701 61x
- Blue anodized Jetmaniac/ADA girldle head
- SpeedySproket Lightened 61x Flywheel
- MagnaPower EXT9
- Bpipe Mod chamber
- Custom Xmetal waterbox
- Single 46mm carb (jetting specs)
- Ada blue throttle wheel
- Prok F/A with pre filter
- JSS Ebox with MSD enhancer
Pump:
- Skat Trak 145 14 vein setback
- Skat trak trim 86/89 nozzles
- EME cone
- 11/17 impeller
- 650sx Driveshaft
- ADA billet Couplers
- Skat SXR scoop intake grate
Steering & Pole:
- RRP Cast pole
- EME bracket with dual breather hose
- RRP bearing steering
- RRP straight bars
- Blowsion Billet throttle lever
- Odessey trim lever
- Skat trim cable
- ODI TLD grips
- Jetmaniac BB Yamaha Throttle cable
- SXR steering cable
Pics when picked up:
Specs:
HULL:
- 2013 EME Q8 Sky
- Xmetal scupper
Engine:
- 701 61x
- MagnaPower EXT9
- Bpipe Mod chamber
Pump:
- EME cone
- 11/17 impeller
- 650sx Driveshaft
Steering & Pole:
- RRP Cast pole
- RRP straight bars
- Skat trim cable
- ODI TLD grips
