Quinc
Buy a Superjet
- California
And a Coffman sizzler.....
Is a great pipe when tuned and setup correctly. =)
For the weight, more stuff to go wrong, limited space, I'm happy with my set up.
There was also a guy in here (can't remember his name) that tuned MR2's that had a setup in testing. They were using Kawi 650's as a test bed and doing ok with it. But that's also been a couple of years.
It's semi tricky due to injecting the right ratio of fuel and nitrous. Separate fuel pump and regulation to match the nitrous?
I'm sure it's doable, but is it really worth the greif? Pump tuning and the whole package in general.
I like my linear, predictable, reliable power I have now.
Watch the PFP video with this Polaris/Lenzi+ nitrousBut just think if right as you where going up your setup wake for a back flip you could give yourself a 30-50hp boost for just those few seconds. =) Running wet nitrous should take care of the fuel/air ratio.
Wet system was what I was thinking. But you might need an electric fuel pump / regulator to get it right. I'd still rather have a well set up package and not run the squeeze.
I've run a few systems on (mild) gas motors and they are very reliable and fun when done right.
I'm no expert though lol!
It just seems you'd be over propped when not on it and propped right when on it?
As it is, on a well set up package you go from low rpm to peak, just hitting your set up wake. And that's in any cc motor.
The quest for power...
