- wichita, ks
mine revd good dry and just needed a slight turn on bottom to make it right in the water
im running a 155m 125p on my 762, you'd be surprised how much fuel these things want!If I put a 140 pilot in wouldn't I need to put a smaller main jet in it? A lot of setups I see have smaller main jets and bigger pilots. Two 140 jets per carb seems like a lot of fuel for an 850.
Best I could get was 135 pilot 115 main one turn out on the screws.
Still runs mostly crappy. If I Brap Brap Brap it's like it loads up some times it's ok some times it FLOGGS!
Off idle. pintch throttle. flogggg.
Motor runs but it won't rev up. But if you run it quarter throttle for 15 seconds and pintch it it goes wfo like it should. But if you go wo then let off then go wo most times it flogggggs. It's like a donkey. Hehaaa.
This portion before the hit gives a poopy sort of thud bog down low before the hit
Here is the enhancer curve it's much more snappy and very clean sounding down low, great throttle response.. the other curve I softened some to help with the poopy sort of bog thud down low, it helps but doesn't eliminate it
