So I have an MSD ewci with a factory type 4 pipe. My ewci is the older style only adjustable through the dip switches and has a lowest on point of 3500rpm. I'm aware of the setting to 3 cylinder trick to get it to kick in sooner but has anybody tried wrapping both spark plug wires with the sensor wire to effectively cut the kick in rpm in half? I guess I don't know if this would cause some type of interference or blow something up. It seems like the type 4 doesn't need water injection in the mid to top end but could use it down lower than my ewci currently supports.
