Took her back out today and there was a steady 6-8mph wind. A friend of mine was out here with me that is into boat racing and gave me some tips on using the wind to my advantage for testing speed. I also gave it a 1/4 turn on the high and low. I hit 57.4mph! And in all of its glory that I used a bad word Coffman pipe bracket broke in half... It is a thick solid piece of steel too! I replaced all of the rubber dampeners, bolts, washers etc.. I even sanded the bracket and painted it so if there where any small cracks starting etc I would have seen them. @TheBuzzard Any tips on keeping this pipe from becoming a recurring headache? Should I add dampeners to the part of the bracket that bolts to the cylinder (Where it cracked)?
Yes we spent afew race days on the beach for this exact reason. The protec wasnt much better but it was still alittle better than these.Only advice is to make sure that there is no binding or pressure on the chamber when it gets bolted to that bracket. We did have to use a couple thin shims. It still broke but took longer. I looked last night and i still have a brand new complete system in the box.Must have been my last replacement from them.Never did use it. Glad to see this is fun for you.I remember going through all this 20 years ago.
