- North Carolina
Ride report. Holy crap. This thing is is a different ski. Bottom end is violent. I love it I cant wait to get my new prop on it. It hits so hard it's got me trying to get further over the nose to keep the ski hooked up and that's with my super short pole. It's great gobs of power everywhere. With one exception. When it runs out a few rpm's it starts to stutter/bog. You can let off and give it a second and it will come alive again. Keep it out of the high speed circuit and I pulls like a beast. The Ada head doesn't get so hot that it would instantly burn you but you definitely can't hold you hand on it for 2 seconds. I guess what I'm saying is I don't think it's getting too hot. Also you can lay your hand on the pipe past the water jacket and its bearable. So a quick run down on the specs again are 760 64x 200 psi both cylinders, .060 squish, 100LL av gas, riva freeride pipe, msd enhance 0 degrees static timing, vforce3 reeds, stock dual 44 carbs, 32 psi pop off. 135 main 115 pilots, low speed screw out 1.5 turns and the high speed out 1 turn. I love the way this thing comes on the power and I tried turning the highs out a little it seemed to soften the bottom some and still brought on the stutter when the carb came into the high speed circuit. I then went in a half turn and it seemed to take a tad longer before it started stuttering. So I closed the high speed jet all the way and maybe it got a little better. It was cold and I didnt want to burn up my motor the first trip out so here I am asking for help from all the carb tuning gurus. Oh yea and the water coming out of the pisser was hot but I could hold my hand in it.
