- Pueblo, CO
Man I hate to burst your bubble but lining your pump shoe up using an intake grate is the LAST way to ever do this.
You need to drill your drive shaft hole (hoping Tim's guide hole is close) and assemble your pump. Bolt an intermediate housing without the shaft onto the fire wall. Slide the pump w/ shaft and pump seal in from rear through the intermediate housing.
This is how you line your pump shoe and pump up properly. Your shaft needs to be perfectly center of you intermediate hole inside the hull then mark and shim your pump shoe location and your pump holes PRECISELY! Remove the pump, drill and glue. Your intake grate will be the LAST of your worries as it can be modified to fit later.
If you want this thing to run with minimal vibration and wear to your intermediate shaft and drive shaft and everything else you need this step to be done PERFECTLY. That means the drive shaft and pump and pump shoe all need to line up perfectly with the hole in the intermediate housing.
This is your most critical step bro, I hope you take the time and get it right or you will be trashing parts for as long as you own this boat and or starting over once you ride it the first time. Get the pump shoe and pump correct before moving on and take no short cuts.
Good advice here Paulie - don't worry about the grate right now, get the shoe aligned to the pump and midshaft fitment first.
