- CT
I think it is a Motoine Kawasaki pipe, but I can't seem to find any info on it. I found this one as well.
Yep had them bring it to worlds for me. Anyone who wants one. Hiro can translate to get anything here.
Half dry with water injection. It's a very cool setup.the way it loops up im guessings its a dry pipe....with possible water injection?????
The people who are really serious about creating a completely new exhaust system should spend the extra time/money to put some numbers into a two stroke expansion chamber design software just to get a reference in relation to existing designs. Without any kind of R&D it's a shot in the dark based on somebody elses design (ie copying).
Building one pipe, testing, revising and ending up with better performance than the previous model and ending with that is not R&D, that is trial and error.
No back to back test yet?? Really curious.
I'll make a guess at what the back to back tests will show:
Original PFP dry chamber will hit like crazy mid to upper rpm power. RRP carbon wet chamber should be noticeably better low to mid range and possibly go flat up top. That's just my guess. I'm really curious to see what the outcome is.
Brian, so it is gonna be the best of both worlds.... More bottom/mid and a couple of pounds less (about 15 including water savings)....
I had ordered a PFP from Thrust but deciding to change for a RRP.
How does the half dry work? The wetjet pipe (made by westcoast) is supposedly a half dry, the manifold and first part of the "headpipe"is dry, and the second part of the chamber is wet. Would this be a similar setup? Plus the wetjet mani is equal length, it's a really nice piece that I think would work well for a custom pipe.
I never knew that's what was in there. A friend has a wet jet and I looked right at that pipe this summer. Pretty cool setup.
