sharkcus
Breakin' the atmosphere.
- Strongsville, OH
Quick history on my setup:
I have a fancy ported 61x cylinder. Stripped all head bolts because this
Drilled out, helicoiled, and used bigger bolts. They have a more coarse thread. The bolts go in tight and give no indication of backing out.
I was out yesterday, did a WOT run on my way back in, maybe 20-30 seconds? Ski randomly died, but started right back up....but it wanted to die if I didn't give it throttle. It still ran enough to get me back in at a decent speed. There were no visible signs of problems on the motor. All bolts were in and appeared tight.
I got home, did a comp test, coupler side cyl was normal. Stator side cyl had 0 compression. I figured I blew the oring.
I pulled the head off, all bolts still appeared tight. The piston was not carboned up at all compared to the working cyl. The oring looked to be perfectly good. Piston looks good, rings appear okay.
I guess my question is, when you blow an oring, doesn't it melt or literally blow out? If my bolts backed out enough to let compression out, wouldn't it melt the oring? Because it didn't. Oring looks mint.
