b pipe chamber ?s
has anybody seen a chamber like this one? just got it on a ski i bought
howd they get that pipe in there thought blasters were different my white ski has a blaster pro tec pipe that was cut and rewelded to make it fit. guess i am the sj guy with the blasted pipes in them.will find out tomorrow how it works
'Crockett
Freelance Smartass
701 WaveBlaster Limited
The Factory Pipe 701 WaveBlaster Limited pipe set the industry standard for this popular machine and it remains the best pipe available. With over 18 additional horsepower and much more torque then stock, this pipe really wakes up the 701 engine. And, with our exclusive tuneable headpipe, you can put the power where you want it or add the optional ECWI® system for electronic controlled tuning. The Factory Pipe 701 WaveBlaster Limited includes tuneable headpipe, high volume stainless chamber, tuned exhaust manifold and all required hardware
waxhead
wannabe backflipper
gold coast
i didnt know there was an old wave blaster mod chamber
i thought there was the limited and then the wrap around mod chamber
you got it mate
Jarred,
The Mod Chamber IS the One that wraps around the flywheel cover.
Like Tims TNT shape. Center bleed.
Sorry Mile..but Croc is correct.
Mile9c1
X-H2O.com
Grand Rapids, MI
You guys are sooooooo wrong... newbies! :rolleyes:
It is definitely an old mod chamber. The limited blaster chamber is bigger and uses a Lord mount on top. I don't see a Lord mount on this chamber. Hmmm. Also it's not all dented to hell like a limited chamber would be to fit in a Superjet. Hmmm. Also it has the slanted weld mark on it that I don't recall ever seeing on any limited blaster chambers. Hmmm.
I've had two of these chambers, there not even close to the limited.
Newbies!
'Crockett
Freelance Smartass
Well, Im far from a newbie . . . . the top mounts were a pain and were somtimes cut off . . . I've got a Blaster mod pipe with no top mount just for that reason.
I have to admit I missed the seam in the picture . . . if I'm not mistaken the "early mod" pipe to which you refer is the same Limited pipe I pictured with about 1.5" cut out of the center of it just like the way they make the Limited SJ pipe into a Mod by shortening it. . . . . . Do you agree ?
If the pipe Fly2day has is a center bleed pipe then I don't know what it is . . . . .it must be something really oddball that was cut up, rewelded and then recoated. Alot of experimenting went on "back in the day" so it may be something "custom" .
Since we're talking about 'Blaster pipes . . . . . . There is another unusual Factory Pipe chamber floating around out there that you guys may run accross some time . . . . . it's a FPP 'Blaster MOD MOD pipe . . .that's a standard "wrap around center bleed 'Blaster Mod pipe" with a section cut out of the middle of it and then rewelded. If I recall correctly, this shorter "mod mod" pipe is actually the one that Tim Tynan's TNT pipe is based on. They were primarilly used on strokers.
Since we're talking about 'Blaster pipes . . . . . . There is another unusual Factory Pipe chamber floating around out there that you guys may run accross some time . . . . . it's a FPP 'Blaster MOD MOD pipe . . .that's a standard "wrap around center bleed 'Blaster pipe" with a section cut out of the middle of it and then rewelded. If I recall correctly, this shorter "mod mod" pipe is actually the one that Tim Tynan's TNT pipe is based on. They were primarilly used on strokers.
I have one of those chambers. i thought it was made by ADA.
http://www.x-h2o.com/threads/4871
'Crockett
Freelance Smartass
Yep, that's the one . . . They are stainless so they polish up nice like yours and make a great looking pipe.
As for . . ."Made" by ADA . . . . No . . . it's a Factory Pipe . . . .
Modified by ADA to go with one of their Billet Stroker cylinders ? . . . now, that would be possible. . . . .
I honestly can't say that they could be ordered as a "mod mod" directly from Factory pipe, I've never seen them listed in their literature or on their website . . . . . .but I have seen them with the FPP 'hammered finish" coating on them so I always assumed that they could be purchased that way . . . . .
Direct from Factory Pipe
Blaster Mod Chamber.
Just got it From UPS 3 days ago.
"If I recall correctly, this shorter "mod mod" pipe is actually the one that Tim Tynan's TNT pipe is based on. "
This is controversial with regard to who based what on whos design.
Where is it shorter ( what section)
How much can I accept to pay for a blaster mod pipe.I would like to try one on my lamey motor.Maybe try to shorten it
