- South Africa
I found this today and have emailed to see if they can supply a kit for jetskis:
http://www.ecotrons.com/2_Stroke_Small_Engine_EFI_kit.html
They have replied already:
Yes, we have done that conversion. There are 2 ways: single throttle body plus your own intake manifold.
2 separate TBs, you do the mechanical link.
$799 for the kit.
Wow, thanks for the heads up.
Looks like they use a MAP sensor to calculate load (speed density), rather then measuring intake volume.
I like the O2 sensor capability for tuning purposes, then removal for open loop operation, plus the EGT feature is nice as well.
Not only that but with a MAP SENSOR You could ride in unfamiliar areas with out the fear of getting lost..... I think that's a cool idea.
If that MAP sensor ever gets wet, the moisture can affect how the device reports pressure levels by not recognizing the appropriate changes within the intake manifold.
What do we think about adding remote mounted solar panels to help power the new computer. I know some riders dont like safety lanyards but a quick disconnect wire from a helmet mounted solar panel would serve a real purpose. Now you can efi and save the planet at the same time. Who says two stroke riders aren't environmentally concious
