Well, this thread has given me lots of great insight. Our goal is to provide a great entry level hull that most will be able to afford, it will be strong and lightweight. It will also offer 2 bottom decks, so no matter if you have an SXR or a Superjet, we are hoping to provide you with a hull your driveline will drop right in and go.
What we are planning to pride ourselves on is easy installation. Due to feedback from you, 99% will be sold assembled unless requested. This will give us the chance to chase threads, and actually mock up the driveline with the parts we have so you can be sure all of your parts will bolt in and be ready to go. I have seen the other budget hull that failed on here, and at the suggestion of others I did some research.
Pricing is still up in the air, but I want to be able to sell a fully assembled and plumbed "basic" glass hull for under 3k. Basic meaning no turf, gel coat finish, no footholds, no scupper. Just a bulkhead installed, top and bottom bonded, cooling/trim/steering/exhaust tubes and fittings installed, inserts for battery tray and motor mount pads installed. I think at that price range it will give a lot more options to those looking to get into an aftermarket hull.
