1996 to 2020 Yamaha Superjet nose reinforcement/repair pieces (Upper and Lower)
tomski
X
LHC
Since I haven't actually posted a new product release page for these products I think the time has come to advertise these items.
I designed and built these to fit over the existing top deck or hull. The edges are finished along with a polished surface for a clean look. They can be used to strengthen the front flange or can be used to overlap light damage. For major damage I recommend graft in pieces which I can also make. Installation is very easy as I pre-fit every piece to ensure proper size. Any two-part epoxy adhesive can be used per personal preference.
These have a gel coat finish with vinylester resin used for lamination. I use uv marine clear for the visual carbon pieces. Standard lay-up with chopped mat, cloth, and double bias material.
Upper and lower together in black with visual carbon - $450 Black or white together - $350. Other colors are available at an additional cost. See individual pricing listed below.
Upper reinforcement/repair piece (1996-2020);
Black with visual carbon - $250
Black or white - $200
Lower reinforcement/repair piece(1996-2007);
tomski
X
LHC
This is another item I have for the 1996-2007 superjet. This reinforcement/repair piece fits under the lower flange area. It can be used for strengthening the nose or a small repair. The use of a two-part epoxy adhesive is recommended for proper installation.
Gel coat finish in black or white, $200 Other colors are available at an additional cost.
tomski
X
LHC
I can also make graft in repair pieces for people who want to return their hulls to original specs.
Upper $250-$400 (carbon nosepiece is extra).
Lower $250 for this size.
tomski
X
LHC
How about a SN nose piece and bumper in one?
And a bottom half reinforcement for SN
I think the nose cover and bumper in one is a bad idea. It would have to be two pieces.
I'll gladly build the lower bottom half reinforcement. But I would like to see more than just a few people request it.
I would go for a bumper and lower reinforcement if you got into doing those. . Ive seen these in person multiple times, your work is superb! Ill spread the word to the square riders and see if we can get you some business!
tomski
X
LHC
Let me know, thanks.
High Speed Industries
Your one stop shop for quality parts @highspeedind
I have this nose piece on my sj, and it's great. I've slammed the bottom of the ocean quite a few times since I've had it. I don't have a single stress crack on the nose of my ski because of the reinforcement.
Bump for making your ski a surf weapon.
tomski
X
LHC
An update;
A few years ago Watty at Random Performance made a purchase of two of my products. Even though I still market these, he decided to splash my part and call it his own.
There is no glory.
