- Enfield, CT
Chris where in CT do you ride?
Dang I never Put mine on a scale and I asked for a reinforced flatwater layup. Oh well, still rips...some thing are better not knowing haha
Im sorry but you pay for a light wieght hull the first thing you do is scale the thing when you get it.
Its like all these guys who buy ADA heads and then dont do a comp test before and after. Well ADAs website was wrong for the kawi 800s and the domes they listed to put a motor at 180 in fact put the motors to 150. SO all these guys but the head bolt it on and make the same power or less than a stock head. You always check what you buy.
ADA specs are with no porting cylinder. The higher the exaust port is raised, the lower the compression is.
All i know is ,took mine out yesterday for its maiden voyage test sesh,and THIS THING FLAT OUT RIPS !!!!!!!!!!!!!!!!! .you would be better off putting your scale away and grabbing your "A" game ,your going to need it. BOB is a bad ass for sure ! ..the way i see it is,Derrick knows strength wise were these standard lay-ups need to be. if he built you a "super-light"glass hull ,you would probably be bumbing when it starts having structural issues ,which would you rather deal with ? that freak in the picture is a glass hull ?? my BOB went right together with ease(less than 30 hrs start to finish)and i'm SUPER impressed with Derricks hull.i put a limited sxr motor in mine and this things a BEAST ! it literally feels like a 1 liter in his hull,so i would ride it first before you become disappointed about anything ....No, but im talking on stock sxr motors they are wrong. DO a search there are many cases, and i myself have seen it on 4 motors. This thread is about Chris build not for me to teach you how to order domes from ADA.
I was making the point you always need to double check what you are buying not just take an aftermarket companies work for it.Take it easy bro, its you who start talking about ADA dome, if you dont wanna talk about it just shut up!!
