Since I haven't actually posted a new product release page for these products I think the time has come to advertise these items.
I designed and built these to fit over the existing top deck or hull. The edges are finished along with a polished surface for a clean look. They can be used to strengthen the front flange or can be used to overlap light damage. For major damage I recommend graft in pieces which I can also make. Installation is very easy as I pre-fit every piece to ensure proper size. Any two-part epoxy adhesive can be used per personal preference.
These have a gel coat finish with vinylester resin used for lamination. I use uv marine clear for the visual carbon pieces. Standard lay-up with chopped mat, cloth, and double bias material.
Upper and lower together in black with visual carbon - $450 Black or white together - $350. Other colors are available at an additional cost. See individual pricing listed below.
Upper reinforcement/repair piece (1996-2020);
Black with visual carbon - $250
Black or white - $200
Lower reinforcement/repair piece(1996-2007);
