feartheride
feartheride
- St.Catharines,On.Canada
I just purchased a 2000 xl 800 that needs motor rebuild and as I am use to 701,760 platforms ,I am looking for any tips..I need to split the cases to se if I can save the crank.
This platform is a bit different as it has the flywheel cover as part of the front motor mounts.Is it best to unbolt the front cover and leave it in the ski with the two front motor mounts attatched or pull the whole thing..trying to avoid having to re prime the oil pump..
Which brings me to the question ,how in the heck do you work on flywheel or stator on these if you have to pull the front motor mounts every time..do you just block up the center of the motor..This is a strange design..
Any thoughts on what the cause of failure could have been,from the pics of the rear piston I provided..Front piston is o.k. back totally fu**ed..
If it was a lean issue,I need to correct it so as to not kill mew motor..
Also can this head be saved or just look for a used one...
Does anyone have a manual I can download or email me
