Freestylegeek's squarenose conversion
Does the back of the topdeck extend beyond the lip/bottom hull then? I have some trouble picturing this.
romack991
homebrewed
Warsaw, IN
Looks good geek! so cutting the hull isnt really supposed to hurt other tricks? I was still debating that since I'm not that dedicated to only tricks.
hmm, i should get motivated and try to keep pace with you guys...
F
Freestyleriverrat
I rode Malones boat and really liked how it handled. You can easily bring the nose up but it would also carve like crazy. Sweet ski. I like the shorter hull as well.
F
Freestyleriverrat
So is the bottom deck of the RN and SN hulls 100% identical?
RN pump and everything fit a SN like original?
Yes, but Malones boat has a SXR style bottom on it which explains the great handling
waterfreak
I had a vision!
s florida
That shorter hull will make a huge difference!!:biggthumpup:
Cool build Matt, keep us posted:woot:
This boat should be alot lighter than an oem roundnose .That SMC sure is some dense heavy stuff:frown: Unfortunetly, most of the weight lies in bottom hull itself.
Do you have a front nose mold to rebuild the lip area?
romack991
homebrewed
Warsaw, IN
No, the front nose of the square is cut off and then you use a mold to glass a new one for the roundie, the rest is the same. only component that is different is that the intermediate hsg on the 90-93 has a different bolt pattern.
The square hull has six inserts for the rideplate - roundie (at least mine) have only four.
