OCD Solutions
- Rentz, GA
Duh, 79 ft/lbs ! Please, advise what manual might that be?
Sorry I meant 75ft/lbs. Clearly stated on the TBM instruction sheet that came with the fw's.
i dont believe ryan has a 61x stator , he said it was off a 97 sj so unless it was switched by maybe previous owner but i doubt it . i believe it was machined to much which allowed it to go on further than supposed to possibly
I've had two TBM flywheels. First felt tight like that and cracked within a couple hours. They refused to warranty it too. They claimed no one else had ever had a problem. That's obvious BS at this point. It also trashed my 8mm stroker crank snout. Dumbass me spent another $500 on another one that also failed within hours. Stock and MSD work fine and TBM can suck me.
That's strange, we've done over a dozen builds with TBM flywheels and they all fit perfect. Tim makes them so the key way is a snug fit on the flywheel. We've never had any problems with them, hopefully its just a couple defective ones..
He said he didnt even know of the epic ignition at all.
Aron...he said that he has never gotten a yami 701 tbm fw back for a warranty that was denied,much less 2.Im just telling you what he said,so you might want to post up what you experience was more specifically.
He also said that tbms dont work well with advent igns,
