Super Jet WHy is my bottom end so bad????????
mademan9
I ride a SuperFrk WannaBe
So I have a bored nozzle on its way, hoppefully that makes a little more. So would dual 38s work a little better? I think I know someone that mit swap with my single carb setup.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Keep in mind, you said to me that you have a 650 superjet pump and nozzle, the plastic nozzle is way bigger stock than a RN nozzle.
Yes, stock '96-up 38's might be better than a single.
If you do use the dual carb 38's don't take out the choke plates and run aftermarket air filters, one or the other but not both for freestyle riding, can and does make tuning harder doing both as the stock carbs weren't designed to do these mods, unless your racing and don't care about needing a big fat jets.
mademan9
ok . Ill keep that in mind. I got a 96 metal nozzle bored to 85 with the 96 steering nozzle. So let me make sure i got this right if i run dual 38's dont use after market air filters or do?
SUPERTUNE
Race Gas Rules
Clearwater Fl.
What hood do you have? Stock hood are just OK not the best at keeping out water.
A good aftermarket hood helps keep water out of the aftermarket air filters, so if you running a stock hood, run stock flame arrester.
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
Or you can plug the 3 holes on the stock hood and it will be quite efficient at keeping water out. Airflow will come from the rear of the hood (can enalrge openings just a bit - but not needed).
