SXR which silicone for pump intake guide replacement?????
i BOUGHT A 2004 SXR-800 AND I AM REPLACING MY PUMP SHOES OR INTAKE GUIDES. I HAVE ORDERED MY NEW ONE. I NEED TO KNOW WHAT SILICONE I SHOULD USE TO PUT IT BACK ON. THE OLD SHOE HAD SOME SORT OF GREEN HARD SILICONE ON IT THAT WAS DIFFERENT FROM THE SILICONE USED ON THE PUMP BOLTS. I HAVE READ MANUALS FOR THIS SKI AND CAN NOT FIND ANY INFO. OHHYEA WHEN I REMOVED THE OLD PUMP SHOE I DID REALLY GOOD JOB AND DID NOT DAMAGED THE HULL OR PAINT. I JUST WANT TO USE THE CORRECT SILICONE WHEN INSTALLING. THANKS FOR ANY HELP....
It isn't silicone, and silicone wont hold. The factory uses what's called plexus. You need to use a panel bonding agent (works best) which can be found at most auto body supply shops. West systems also has some great epoxies that would work.
