What is up with my compression... or is it these tester's ?
Shifty
- SuperJet Thursday -
I am still not sure of my compression. I have an '08 SJ, im sporting a limited pipe and a riva girdled head w/ 35cc domes. Before running the head I did a comp test at a local marina... I got 195 across both cylinders on a decent gauge, except he only had the short plug adapter so I would think the reading would read slightly lower. Thinking that was too high for 35cc domes I tested again after burning though roughlyl 10 gals of 93 octane (no long high RPM runs) this time I used a cheap -O autozone rental guage to test. I got 170psi on this guage with the correct adapter for the long reach plugs.
Thinking all of these gauges sucked, i bought a used snap-on gauge 0-300psi with the correct addapter. I have run about 20 gallons with this new setup now and I just tested on my new to me gauge and got 140psi on both cylinders. Whats the deal?
I have checked the plugs frequently and they show no signs of detonation and I refrain from long high speed runs. Why are my reading falling like this? I think I need to go see the guy that did the test originally to see if the reading is the same.
Note - All of these tests were done with one plug in and the throttle wide open.
Thanks for reading my novel,
compression testing
A stock superjet Only has 135 psi compression. No matter what anyone tells you. I have the Yamaha Repair manual and it lists compression at 135. Every compression tester will read different. If you are above 135 your good.
Shifty
Squish; I wish I knew, I dont have a caliper to measure it with though. I think I am going to pull the head and have a look at my pistons and cylinder walls. The ski runs good, a little rich actually.
Shonuff
I've got the glow
Memphis
All my stock Superjets have been right at 150 psi on a craftsman gauge.
Bend a piece of .050 solder into an L ,remove the plugs and insert the solder till it touches the cylinder wall,rotate the engine through by hand and remove the solder.You will need to take the solder to someone with a caliper or micrometer to measure the portion that was flattened but that will tell you what your squish is without removing any parts and it is dead on accurate.
Shifty
Ok, on my lunch break I ran a little test. I have two adapters, a short threaded and long threaded. I jacked my compressor up to 110psi and shot air into the gauge fitted with the short reach adapter... reads 110psi. Try that with the long reach adapter and I get 40-50psi. After swapping the check valves (tire valve) from the end of each adapter I am now getting 197psi on my motor,
I am happy my gauge is working well and my motor isn't loosing compression, but I am @ 200psi:shocked:
My plugs look good and I am not blasting away for 5 minute runs at top rpm, am I safe to keep this up witout race gas until I can get new domes, have them machined???
What domes would bring me down to pump gas? What other options do I have to get this think under 185? I will check squish tonight.
Thanks for the assistance,
Shifty
Ok, I measured my squish with some solder and it is at .046. I am still getting about 198psi with this head though. My gauge looks to be about 10 psi on the high side because when it is unpresurized, the needle sits just at the 10psi hash mark. These are all cold #'s also, shouldn't a compression test be performed on a motor at operating temp?
