SX/SXi/SXi Pro what hull should i use for free ride / freestyle sxi or sxi pro
free ride / freestyle sxi or sxi pro hull
  • sxi hull
    Votes: 3 21.4%
  • sxi pro hull
    Votes: 11 78.6%
  • Total voters
    14
ct
i have an sxi hull its kind of beat i can get an sxi pro hull cheep but what ever hull i choose im going to go through it from top to bottom what wound you think wound make a better free ride / freestyle boat?
vitalikol
Jetski-Snowboard
Pennington,NJ
Pro........ And I am sure later on some butthead will tale you to get pooperjet. LOL !!!
Some Yamaha people just don't understand something: I choose to ride Kawasaki and don't want Yamaha.
ct
ya people seam to forget that Kawasaki invented the stand up i started on a 550 and I'm sticking with them and most big freestyle guys run every thing Kawasaki except the engine
ahh, I love shortened style sxr bottom decks, and there pump setup..but eme r the only ones using sxr style lower decks. Xft, Bun, wcf, Max hull, matrix, xs, lenzi, other than his one1 which is in its own class, but sj pump. All these r sj related, so id say most pro riders use sj style. But dont get me wrong im a fan of a mod sxr lower deck.
Do the Pro hull with front tubbies molded in and cut the rear off about 2 inches and you will have a nice freestyle hull that will turn and jump and be stable. As for aftermarket hulls Trinty EVO, WDk Envy, Blowsion and Wamilton all had hulls too based on the SXR hull and the new superjet hull copied it to a point.
Boris
The Good Old Days
I'll chime in.
Neither.
But if it must be one of the 2 than I'd take one that is lighter.
I would have to do quite a bit of grinding on the chines to get them things to slide around a bit more. Guess it's that "SuperJet" thing.
I used to have the sx and went to the pro I love the pro and I pushed the motor back so I could use a 650sx driveshaft ;-) So no nose heavy problems on my end.
how are you guys moving the motor back? are you using the sx motor plate or modifying the sxi pro plate? im interested in doing this.
You can redrill new motor mount holes in the hull or you can slot the holes on the motor bed plate where it mounts to the motor and where it mounts to the rubber mounts. Be carfull using a 650 drive shaft where it is machined for the bearing support sometimes it does not match up for the bearings and seals.
