jkirkland
jkirkland
- inverness florida
I have a 93 750 sx with a 750 stroker motor, factory wet pipe, dual 44 red tops, and a 12 vane mag pump. The ski rips, but I had a lightweight charging flywheel in it until it spit out a bendix that chewed up the stator and the flywheel. So I decided to try out a jetinetics Heat total loss that I had laying around. The ski has awesome spark and seems to run well out of the water. But in the water it wont clear out and go. I also noticed that my motor coupler was unthreading. So after reading in another thread that the analog total loss can make the motor run in reverse I was wondering if this is what is going on. Could it be too advanced or too retarded? I guess I will have to get a timing light and take the chamber off and try to time it. I have no Idea where the timing is at now I just left it in the same postion as the previous owner. (Pick up is on the timing cover) Thanks for any help--Jason--
