Time to winterize
Well I'm back in school so its time to winterize the '90 SJ - couple questions....
What can I do to be sure no water is left in the block?
I have no pisser to funnel in antifreeze - is there a water line I can use?
Also I don't want to find my carb gummed up next summer (my dad's ski-doo likes to do that) - any ideas?
Thanks for your help, I did a search and these are my remaining questions
3wheelerdude
Talk less, Ride more!
Ontario Canada
For the water, I use a shop-vac and siphon all the water out of there.
For the gas and carbs, I put fuel stabilizer (sta-bil) in the tank and run the ski for a minute or two (do not run ski for a minute out of water) .
I also fog down the engine and take the battery inside.
time for all the winterizing threads with the "whats that?" jokes to follow!
i love it. winterizing down here means put some premix in and ride!
speaking of premix, isnt it true that premixed fuel will NOT separate and gum up like unmixed fuel?
Frosty
New York Crew
Western New York
i usually just put sta-bil in the tank then run the motor to circulate the sta-bil into the fuel lines and carb. while running it I fog the carbs until the motor chokes out, usually does not stall, but choke and sputters. then I pull the plugs and fog down the cylinders, then drop a cap full of oil in. then spray down the entire motor with a rust inhibitor. I never use antifreeze in mine...
Also, if i don't leave mine in the heated shop, and just stick it in the garage, where it's subject to freezing and warming, i prop the hood open to keep condensation from building. I also drain my fuel tank after running it, and leave it slightly open with a sock or something over it to allow it to breath and not build condensation in the tank either.
this year though, i will not winterize until mid january... Daytona Beach here I come. :biggrin:
