TBM pump cone
VXSXH20
Sionis Industries
Mid-Atlantic
Adjustable how.? They have ones that you can physically stack/add spacers between the cone and the pump housing?
-Side note WetWolf makes the " Adjust-a-thrust" which has the white nylon sleeve that automatically adjusts-extends/retracts while under load when riding.. I have no review for this as i do not have one nor have i ridden a ski with one on it. I believe they are more tailored for couch skis/racing market
The TBM is a "big hub" conversion piece for stock pump stators. Similar to the R&D and Blowsion. The TBM comes with 3 different tail cones that canbe changed by removing 1 bbolt, the R&D uses the "shim" design. The Wet Wolf that was mentioned and "adjust-a-thrust" is a replacement tail cone only. I used a TBM in a Kawi 140 with fair results, there was improvement in hookup compared to stock. If picked up "on the cheap" they can help, but for a Yami having the Solas Stator option is the way to go imo.
