Quinc
Buy a Superjet
- California
Going to take 2" off the back and rocker the nose. just kidding!
Swapping my zxi1100 guts into one. Engine has all the normal mods, dry pipe, shaved head, cleaned up ports etc. Pump has a Solas concord impeller.
Threads are deeper on the sxr than the zxi so went up a size on the motor mount bolts:
Coupler swapped onto sxr driveshaft:
zxi runs hot so water fitting drilled out a size bigger.
Lots of fittings in the pump area! Had to blow air through each one to see where it went. Thinking the sxr comes with dual cooling from factory?
Every thread gets chased and every bolt gets cleaned as well.
New gas tank came in the mail today!
Need to figure out how I am going to do the fuel pick ups still. Any suggestions?
Hood hooks came today in mail as well and are now installed!
Anyone know which end of the steering cable goes toward the pump?
