- Beach Haven, NJ
Searched and did not find anything answering what is happening with my 2002 SXI Pro.
I just rebuilt my carbs using the genuine Mikuni kits. My pop off is 34 psi in both carbs. I started with my low speed screw set at 1/2 turn out and high speed at 1 turn out as per the service manual. Ski will start up and idle but falls on it face the second I touch the throttle. I adjusted the low speed screw up by 1/8 turn on each carb until it was @ 2 + turns out on each carb. Ski will idle best at 7/8 turn out but will idle fine all the way up to 2+ turns out. Still falls on its face when I touch throttle. I can get it past this by choking slightly and then it rips up to full throttle but anytime I let off below 1/4 throttle it will die.
My ski has stock jets. I am not sure what size (forgot to look). Do I need a different low speed jet? Fuel filters are not clogged. I am stumped.
