superjet reeds
how about reeds who make the best
any mild motor stock is fine.. if you have more work than look into different reeds. i use stock kawasaki zxi 900/1100 with larger carbs and custom intake set up.. what motor work do you have done? reeds are a fine tuning enhancer when many other updates are performed. unless they are broken..:crutches:
Reeds typically offer very little performance difference IMO. Stock are fine on most mild motors. I personally run carbon tech. I have seen 2 times where stock metal reeds broke and ended up going through a motor. Not good.
