Superjet midshaft seal oem vs common Hyd shop seals
Alright- been searching without success
During the summer I was in a hurry to assemble my ski.
Needed two mid shaft seals, instead of wait for the oem double lip seals I used common seals from any hydraulic store (single lip). These seals fit tighter then my old double seals on the shaft and are a good snug fit. So far so good, they appear to being doing a good job.
Anyone see any reason to change them to the oem seals? Or keep
Running the hydraulic single lip seals?
Will try and post a pic or to shortly!
Stockton
The tension on the lip seals you used may cut/wear a grove in the shaft where the lip rides if they fit snugger than new OEM
john zigler
Vendor Account
wisconsin
Also, on most standard seals, the retainer spring is standard steel, and will rust / break. OE have stainless springs, intended for marine use.
