Superjet gas filler tube?
tx
I'm new to the brap world. Bought a B1 few months ago I love it.Bought a SJ that hadn't ran in years I've gotten it to run its way harder ride, and way faster the SJ is a 90 w/650 . Anyway I noticed that the rubber tube goes to gas tank lays on water box which is metal and tube seems soft and thin where it touches water box is this normal ? Is this dangerous?Also the SJ has a aftermarket pipe ,170psi each cyclinder seems to rev higher than B1 /701 but when I'm able to hold SJ wide open it seems to run out of water it has after market intake and a ride plate and a aftermarket prop.Why can't I keep the pump hooked up?The ride plate had been shimmed with washers and a ton of silicon even on the hull , I digged the washers clean off the silicon and bolted ride plate back on seemed to help some with the cavition. I'm not saying the SJ isn't fun but it's really hard to ride.what
