Y
yamaslut
Guest
I'm sure this has been covered a million times, but here's my version..
Ace Hardware - 5/64 SS Cotter pin, 5/64 drill bit..
- Drill bolt through nut and post while nut for steering is installed at desired tightness..
- Make sure this is the spot you want it...
- Use a cutting wax or some oil so you don't burn up the bit right away.
- slide pin in the hole to ensure clean fit
- bend the pin so it locks into place good and won't slide out
