- Quebec, Canada
Hi ! where can i get a new pump seal for my 122 pump for my Fx1 ?
packing 62L-51117-00-00
thanks guys
thanks guys
I have a complete pump, with stock prop, was rebuilt last season with wsm kit.Hi ! where can i get a new pump seal for my 122 pump for my Fx1 ?
thanks guys
Actually may be a real problem finding a pump seal for a 122. Probably one hasn’t been made in a long time. Seems like @DrewOregonian has the best option right nowThanks a lot but my pump is great with solas impeler but i have some cavitation and i want to change the seal at one just to be sure its not the problem !!!
Is the cavitation new?Thanks a lot but my pump is great with solas impeler but i have some cavitation and i want to change the seal at one just to be sure its not the problem !!!
i found problem !!! my seal was sealed perfectly at top !!! just put a light into tunnel and see the light come out between pump shoe and pump seal !!! im gonna put a little bit of silicon around this seal to be sure it sealed good !!!! but if someone have a good seal i would take it !!! thanks
Don’t seal ride plate with silicone. Will cause cavitation.did you seal all the hole with silicon too on ride plate ???
