Check it I got up for sale or trade
It's a 92 square nose superjet.
This Is not your normal suare nose
The hull was shortened about 5 inches off the back. The motor compartment was ground down and reinforced.the side rails were cut down and reshaped. A versa plug scupper valve was installed. I believe they are blowsion foot holds. The tray and rub rails have newer turff. It has a square nose pole that has been shortened about 6" give or take . Has a custom duel bilge bracket with duel bilges installed. The motor is a 6m6 that has been polished and jetted. Has ocean pro Flame Arrester, boyson carbon fiber reeds. I'm running a cheater pipe that has been Lengthen by 5 inches at the Cupler with a little reshaping of the stinger cone. Running a ProTech computer with adjustable rev limiter. The pumps been drilled for dual cooling with a 12/16 scattrack impeller and a jetmanic heavy duty impeller shaft.Im also running a board out pump nozzel with a quick steer mod. The pump has two small test rides since it was built at the end of last summer. Both motor and pump have been shimmed for best possible coupler ailment. It has all the goodies primer, duel bilge switches, a tac ( I pulled it off to change the dash panel up but I still have it), limiting rope, o degree bars, blowsion finger throttle. All water and fuel lines were replaced mid last summer. The regi is up to date and good thru june of 2013. the ski is in my name and I HAVE THE PINK AND REGI IN HAND
This is one of the sickest square nose superjets that I have ever seen. I highly doubt that you would come a crossed another square nose on this level.
I'm asking 4500obo or trade for a round nose with a 701. For the right deal I have another 91 square nose and a two ski trailer I may be willing to barter with FOR THE RIGHT SKI!!!!!!!!!
SERIOUS INQUIRIES ONLY!!!!!!!! DO NOT CALL ME AND OFFER ME $2500 CASH!!!! DO NOT CALL ME AND OFFER ME A 550 AND $200 CASH I WILL LAUGH AT YOU AND HANG UP SERIOUS INQUIRIES ONLY.
IM LOOKING FOR A ROUND NOSE SUPERJET OR CASH!!!
May consider aftermarket hull skis.
My name is cas and my number is 5108605422. I can send more pics and info if needed
The picture of the silver ski is the other superjet I may be willing to barter with if the right ski pops up
