shortening a rrp
Proformance1
Liquid Insanity
Vendor Account
New York Crew
FYI, You can shorten quite a bit if you do the top and bottom adjusters without cutting. Just making sure you don't cut for no reason, I'm sure you already knew. :sad6:
THRUST
ThrustInnovations.com
you can also cut your tube around them with a dremel or with a hacksaw cut half push the cable to one side and cut the other half . then cut your scrap piece in the middle and remove . this will save you an hour or so
