Super Jet School me on steering setups.
Quinc
Buy a Superjet
California
Can I get a UMI quick steer plate and use it with the stock steering bushings etc or do I need to get a umi bearing setup? Also are the stock bearings (plastic bushing looking piece) worth replacing with new oem, or will the steering still be loose and sloppy?
Running an ATP nozzle and looking to get the quickest throw possible.
I wouldn't waste your time with the umi, either go with the cold fusion setup if you want some thing that is trouble free and doesn't use bearings, otherwise blowsion has a new setup
NVJAY775
My home away from home.
The Blowsion only works with their pole though. Kind of a bummer... ATP, Titan are also nice with sealed bearings. But for the money the Cold-Fusion is hard to beat. I ran one for 2 seasons with zero issues. Picked up a Titan (used) for this season and it's also nice. Quick steer is nice, but some are finding out there is such a thing as too much nozzle throw. Depending on hull and other stuff...
