- Mashpee Massachusetts
hey guys im new to the forum and came here for help since my buddy told me about the site. anyway so i got an 06 rn superjet. i winterized it when last season was over and that was the last time the thing was running. i have since begun to get it ready. when i went to crank it the other day and it wouldnt crank, not even click or anything. shown in the pic below you can see it has an msd ignition in it and i wiggled the black connector and another white connector that comes out of the left side of the ebox when looking aft of the handpole and it started to crank over. I thought it was a loose connection so i took apart the two little connectors and the connections looked good on both. i also tried unhooking the clear one and cranking with the black connector connected and vice versa with the white but still nothing, not even a click. the next thing i did was open ebox to find some water in it and some corrosion. i cleaned it all up and i actually used a needle nose plyers with plastic grips to jump the solenoid on the two lugs and it cranked. thats about as far as i got though. I guess what i need help with is where exactly do i put the multimeter to find out if the solenoid is bad. i am not really electriaclly inclined. i looked at other threads to see if i could find some pictures of where people put the meter leads but i couldnt. also if anyone is located in the cape cod Massachusetts area and knows what to do i would drive the ski to them and pay some cash for their time to show me how the hell to electrically troubleshoot this thing to find the problem. thanks guys
