SX/SXi/SXi Pro Primer kit install ? On sxi
Just bought a primer kit I have the dual mikunis. Kit didn't come with instructions. If somebody can let me know how to do this that would be great. If u have pics that would help too
Shonuff
I've got the glow
Memphis
If you have your oil tank blocked off, then use the nipple at the intake manifold. Also, you really only have to prime one carb. That's how Full-Spectrums are built.
N3vrSat1sfied
Military Member
Fort Worth, TX
T fitting in your Fuel ON/feed line. run to primer dont know which one you will have to see. then run other line to either intake manifold fitting which you probably dont have. or to the fittings on the carbs you can T to feed both carbs.
