OK. Ran into a snag. I have the protec reduction nozzle installed on my pump, bolt the pump on and shim it properly.....Then I go to bolt on my steering nozzle and it doesn't fit. It seems that the top and bottom bolt holes are too far back on the reduction nozzle. Does anyone know if you can use a regular superjet steering nozzle with the protec reduction nozzle???? What should I do? Does anyone run the reduction nozzle with just a steering nozzle and no tilt mechanism/trim ring? I need to know what part I need to complete the installation???? I also just looked at protec's website and apparently you use a 'steering nozzle spacer kit' for the superjet application of steering nozzle? If that is what I need could someone pitch in here and tell me? Otherwise I'll be calling protec back on monday and being frusterated!!!!
