i have an 04 sxr. i have a wet pipe, v-foce reeds, prop and stock jetting. i always have a bog at bottom end...always..i have to feather the throttle constantly to keep the rpms up so i can pull out of the water. once the power kicks in, its great. if i tip over or submarine it, it takes even longer for it to kick in. like 6 or 7 seconds. what is wrong with it? how do i fix this? i want instant throttle response. it never did this when it was stock. what do i do? i tried leaning out the low speed jets and it seemed like it helped on smooth water, but then i rode it again the next day in choppier water and it felt just as bad as it has always been, maybe worse
