Plastic cooling line T's
Q
QuickMick
Guest
Does anyone use plastic "T"'s in their cooling lines?
I have one I took out, but got to thinking about the weight of a metal one bouncing around. I made one out of plastic fittings that I need. I just wonder if its safe to use it?? what do you think?
Here is the one I made out of brass.
Here is the one I am thinking of replacing it with.. I did superglue all the fittings together after threading them in.
Q
QuickMick
Guest
Dude, what's wrong with just a plastic "T"?
Then the T off line would go out over my fuel tank and back in. Like a big U, this way it is straight. I know it sounds funny but I wanted the line supported, and a lil neat'er
Not sure... I realy wouldn't bother saving the ounces vs. one of those plastic pieces breaking and ruining a day of riding.
Yea, that is what I was thinking.....
I basicially built it to see if it could be done.
I had a plastic T on my GP and I broke it.I now use all brass on that ski (I think I was too violent with it.) I am running a plastic T on my superjet its at least 2 years old now and haven't had an issue
Q
QuickMick
Guest
violent as in surf riding??
90% of my riding is in surf... bang, bang, bang.
Shonuff
I've got the glow
Memphis
Which is odd because Yamahas shake like Katherine Hepburn on meth.
No No I personally was violent with it. If I recall the hose wouldn't come off and I was pissed off already and broke it. I do like the 90 turn on the T makes a cleaner look less hose etc.
Just keep an extra plastic T in the tool box when you going riding. My feeling is if you keep your eye on your pissers and you see no water is coming out you would head to shore. If its broke swap it out and good to go.
Crab
thanks darin...noswad!
Seattle
They last a long time, but I just took one and threw it away since it cracked. Been using PEX brass plumbing tees from Lowes.
